notes386
Apr 05, 2017Aspirant
fvs318g with HP ProCurve VLAN for guest network?
Had an old Cisco router that was starting to die so found a used FVS318G on Craigslist. Swapped out the old router and appeared to be working ok for several weeks. However, our guest network (churc...
DaneA
Apr 06, 2017NETGEAR Employee Retired
Hi notes386,
Welcome to the community! :)
Is the FVS318G you have an FVS318Gv1 or FVS318Gv2? If ever you cannot determine what version, kindly send me a screenshot of the serial number labeled on the device itself via private message.
If ever your old Cisco router supports VLAN wherein the Guest network is configured as one of the VLANs and you have replaced it with an FVS318Gv1, I'm afraid to inform that the FVS318Gv1 does not support VLAN.
DaneA
NETGEAR Community Team
notes386
Apr 07, 2017Aspirant
Appears to be the v1. I put the old Cisco router back in and it is working. I don't think I can put the fvs318g in between the cable modem & the router either. We don't have management access to the cisco router. Have the correct password, but when trying to access it just sits in waiting mode... ;-(
Thanks for the quick reply!
Dan
- niemoyApr 09, 2017Aspirant
Hi,
The FVS318G would not be applicabe replacement for your existing Cisco router because of the existing VLANs. The FVS318Gv1 doe snot have VLANs. I recommend getting the FVS318Gv2 and I hope you can get a new one so you can expect full support and lifetime prosafe warranty from NETGEAR.
Reference manual for FVS318G - No VLAN feature:
http://www.downloads.netgear.com/files/products/FVS318G/Documentation/RM/FVS318G_RM_27Aug10.pdf
Reference manual for FVS318Gv2 with VLAN configurations page 59:
http://www.downloads.netgear.com/files/GDC/FVS318GV2/FVS318Gv2_RM_21Oct2014.pdf
Let me how I can help further.
- notes386Apr 09, 2017Aspirant
Strange, the Cisco EA3500 doesn't support VLan either. We have a VLan switch (the ProCurve) that is doing the VLan activity. And the Cisco has been working fine for a couple years- but it has the "waiting" but so we don't have management access. That is why we wanted to swap it out (with the Netgear we got used locally; church, so need to watch the $$). Wish I could figure out what the router is doing different from the FVS318Gv1...
Thanks again,
Dan
