notes386
Apr 05, 2017Aspirant
fvs318g with HP ProCurve VLAN for guest network?
Had an old Cisco router that was starting to die so found a used FVS318G on Craigslist. Swapped out the old router and appeared to be working ok for several weeks. However, our guest network (churc...
DaneA
Apr 10, 2017NETGEAR Employee Retired
Let us isolate the problem.
a. Kindly try this setup: connect the cable modem to the WAN port of the FVS318Gv1 then connect a PC directly to any LAN port of the FVS318Gv1. Configure the FVS318Gv1 for internet access. Are you able to go online just fine through the FVS318Gv1?
b. Are there any other VLANs configured on the HP ProCurve switch aside from the Guest VLAN? If yes, if you will connect the HP ProCurve switch to a LAN port of the FVS318Gv1, do other VLANs have internet access?
c. What is the current firmware version of the FVS318Gv1?
DaneA
NETGEAR Community Team
