oLaNceLoTo
Jul 29, 2016Aspirant
FVS318Gv2 - L2TP/IPsec Server
Hi, I have got a router "NETGEAR ProSafe™ Gigabit 8 Port VPN Firewall FVS318Gv2" and I try to configure the L2TP VPN Server. I have try to configure like this : And like this : And ...
- Aug 05, 2016
The problam was that I have tested the VPN from my local LAN and it does not work in this configuration.
When I have tested it from a external computer it has work.
JohnRo
Jul 29, 2016NETGEAR Employee Retired
Hello oLaNceLoTo,
Welcome to the community!
Have you tried following the instructions on this KB Link? If not, please check the example posted on the page. I also would like to know what operating system you are using.
Thanks,
oLaNceLoTo
I have follow this all step before poting.
L2TP server is enable with a good range and I have put a user to L2TP Users.
I try to connect from a windows 7 and a windows 10.
Regards.
LaNceLoT
- JohnRoAug 02, 2016NETGEAR Employee Retired
Hi oLaNceLoTo,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- oLaNceLoToAug 02, 2016Aspirant
I haven't find a solution.
No packet from extern source seems to arrive to the VPN and my provider say that there is no firewall or blocking....
I m in an impass.....
- JohnRoAug 03, 2016NETGEAR Employee Retired
Hi oLaNceLoTo,
Did you try testing the connection using the configuration on the thread that I posted? It appears that some users had made a connection using those settings.
Thanks,
