oLaNceLoTo
Jul 29, 2016Aspirant
FVS318Gv2 - L2TP/IPsec Server
Hi, I have got a router "NETGEAR ProSafe™ Gigabit 8 Port VPN Firewall FVS318Gv2" and I try to configure the L2TP VPN Server. I have try to configure like this : And like this : And ...
- Aug 06, 2016
The problam was that I have tested the VPN from my local LAN and it does not work in this configuration.
When I have tested it from a external computer it has work.
oLaNceLoTo
Aug 02, 2016Aspirant
I haven't find a solution.
No packet from extern source seems to arrive to the VPN and my provider say that there is no firewall or blocking....
I m in an impass.....
JohnRo
Aug 03, 2016NETGEAR Employee Retired
Hi oLaNceLoTo,
Did you try testing the connection using the configuration on the thread that I posted? It appears that some users had made a connection using those settings.
Thanks,
- oLaNceLoToAug 03, 2016Aspirant
Yes sure, I have tested many type of configuration, none have work.
- JohnRoAug 04, 2016NETGEAR Employee Retired
Hi oLaNceLoTo,
I think it is best to contact our Support Team to have it looked at more closely.
Thanks,
- oLaNceLoToAug 04, 2016Aspirant
I have contact the support. It seems that is worked for them.
But I need to test it from my side on a another computer to be sure, then i will check this thread as solved if it's ok.
I will try to test it tomorow from the computer that need to be connected. I'll try to answer just after.
