oLaNceLoTo
Jul 29, 2016Aspirant
FVS318Gv2 - L2TP/IPsec Server
Hi, I have got a router "NETGEAR ProSafe™ Gigabit 8 Port VPN Firewall FVS318Gv2" and I try to configure the L2TP VPN Server. I have try to configure like this : And like this : And ...
- Aug 05, 2016
The problam was that I have tested the VPN from my local LAN and it does not work in this configuration.
When I have tested it from a external computer it has work.
oLaNceLoTo
Aug 04, 2016Aspirant
I have contact the support. It seems that is worked for them.
But I need to test it from my side on a another computer to be sure, then i will check this thread as solved if it's ok.
I will try to test it tomorow from the computer that need to be connected. I'll try to answer just after.
oLaNceLoTo
Aug 05, 2016Aspirant
- JohnRoAug 08, 2016NETGEAR Employee Retired
Hi oLaNceLoTo,
Well, I'm not sure how you can test the VPN on the local network. But it is nice to know that it is woking externally. Let us know if you have more questions, otherwise you can mark the post as "Accept as Solution".
Thanks,
- oLaNceLoToAug 08, 2016Aspirant
It's done. I have marked my last post as accepted
