Dlswyo
Jan 15, 2016Follower
Fvs318gv2 connectivity issues
i have a fvs318gv2 with the latest firmware installed 4.3.3-6. It works great for about 10 minutes then it crashes. After it crashes I can ping it, but I can't access it through the gui. I reboot and...
rickgode
Sep 13, 2016Aspirant
I agree 100% This is my 4th Netgear firewall. Each one always came back up after a power outage, except the FVS318Gv2. It's not that I'm trying to access the internet as soon as the power goes out, it's just that I'M TRYING TO ACCESS THE INTERNET WHEN THE POWER GOES OUT!
I have dozens of devices that connect through this firewall, and every firewall before this one would "JUST WORK" So far mine's been up since the last power outage (which has been a few weeks) and everything is working fine.
But to get to this point, took a couple weeks and a new firmware update...
Ricky
shiekh
Sep 13, 2016Guide
I am hopeful Netgear will get their act together, or they will end up needing to lay people off like Cisco recently.
I just took a look at Netgear stock... it has done amazingly good recently.
- SamirDSep 13, 2016Prodigy
I think a lot of those Cisco layoffs have to do with them trimming the fat on acquisitions or divisions that aren't the 'core' of Cisco like Linksys and the Meraki acquisition. I hope it doesn't spell bad things for CSCO. I've owned that stock since 1995...
- shiekhSep 13, 2016Guide
Didn't they sell Linksys to Belkin?
A bit off topic, but I look forward to the day that my Netgear FVS-318Gv2 and FVS-318N are running as they should be.
I don't think they did. But I haven't looked at any linksys products in quite a while now.
Yes, it would be nice if your 318s worked like they should. They are quite nice for what they are when they're up and running.
We used to have some bandaids in place to keep our rv016s up and solid (script to reboot them every 24hrs). We had the same script on our old fvs114, but then had to step that up to a hardware rebooter. Luckily the 114 rebooted in literally a second so that wasn't that big of a deal. Once the 114 wan port died, we put a spare rv016 in its place while I searched for a real solution. During that time, we ran across a great deal on some nib 318Ns and got those. Finally switched out the fvs124g I was using at my endpoint with a 318 as a test. Initially it was super-painful (just like you're going through now), but once it was up and solid, it was great. We installed another 318N at a new location, and again setup was a pain since dhcp was an issue on the firmware we were on. But a firmware upgrade later, it was up and solid too. Then we replaced the rv016 with a watchguard and sold off the businesses where the rv016s were so they came back as spares. I've taken a rv016 overseas to quickly build a tunnel when I need one, but other than that, we've just have them, one 318, and the fvs124g as backups. We still have the 114 and we might put that in place as a switch where we need one. It's amazing how long of a life networking equipment really has.
