Dlswyo
Jan 14, 2016Follower
Fvs318gv2 connectivity issues
i have a fvs318gv2 with the latest firmware installed 4.3.3-6. It works great for about 10 minutes then it crashes. After it crashes I can ping it, but I can't access it through the gui. I reboot and...
SamirD
Sep 29, 2016Prodigy
One thing I just thought of that I've done to each of my FVS318Ns is to disable all flood checks and other firewall features and see if that helps.
I know that on the Cisco rv016s we had, they would think they were under attack by the ISP because the ISP was sending 100 packets/second of ack/nak packets (it amounted to 4k/sec of data--the equivalent to the entire bandwidth of a dial-up modem). And they would drop the wan and not come back up, which sounds oddly like this issue.
The type of modem wouldn't matter since its the head end carrier equipment that would be the issue.
cclo
Sep 29, 2016Aspirant
I just did a factory reset. Resetup my Router and this time everything working. VPN and DMZ... everything. I set the router to do a reboot every night at 4:50 AM. Let see if it can stay up this time!
Man, what the hell is this! Does Netgear know this issues? I just file a support ticket. Does anyone of you have the same issues contacted support? This is bull**bleep**!
- shiekhSep 29, 2016Guide
Don't reset!
The way to get them to work is bring them up with nothing connected, then connect them up; they will work fine till rebooted...
