Dlswyo
Jan 14, 2016Follower
Fvs318gv2 connectivity issues
i have a fvs318gv2 with the latest firmware installed 4.3.3-6. It works great for about 10 minutes then it crashes. After it crashes I can ping it, but I can't access it through the gui. I reboot and...
cclo
Sep 29, 2016Aspirant
I just did a factory reset. Resetup my Router and this time everything working. VPN and DMZ... everything. I set the router to do a reboot every night at 4:50 AM. Let see if it can stay up this time!
Man, what the hell is this! Does Netgear know this issues? I just file a support ticket. Does anyone of you have the same issues contacted support? This is bull**bleep**!
shiekh
Sep 29, 2016Guide
Don't reset!
The way to get them to work is bring them up with nothing connected, then connect them up; they will work fine till rebooted...
- ccloSep 29, 2016Aspirant
I though people say you can just go into the router web setup. Monitoring, Diagnostics then hit the Reboot button. And that way the router will stay up.
- shiekhSep 29, 2016Guide
You are right, I forgot this.
- rickgodeSep 29, 2016Aspirant
The GUI reboot doesn't/didn't work for me after the latest firmware update. I haven’t had a power outage since the last fiasco and when mine is running, it runs FANTASTIC!
I am reluctant to pull the power to test if these
fixesBand-Aids worked. As the last time the power went out it took weeks until it came back up.Provider: Charter
Modem: Motorola SURFboard 6121
Ricky
