Dlswyo
Jan 14, 2016Follower
Fvs318gv2 connectivity issues
i have a fvs318gv2 with the latest firmware installed 4.3.3-6. It works great for about 10 minutes then it crashes. After it crashes I can ping it, but I can't access it through the gui. I reboot and...
shiekh
Sep 29, 2016Guide
I am jealous and will now proceed to sulk...
After a reboot (good nights sleep) I'll be back... ;-)
cclo
Sep 29, 2016Aspirant
Crap, I know why my VPN kept going down. Turning on the DMZ will kill it! Why????? WTF wrong with Netgear! If you put any DMZ WAN Rule in Security will kill your VPN! You can log into VPN. but you can't see anything or connect to anything once you are in!
- ccloSep 29, 2016Aspirant
I just got a reply from support. Because I bought this thing from eBay they say they can't help me with it even the unit is new! What the hell. He said, he things is a defective unit. I told him and a copy the link to show him, it is a firmware issues. But all he care is close the ticket and move on!
Lesson learn! I will never buy NetGear again... This is the final $160 you get from me! Period!
- shiekhSep 30, 2016Guide
I was also told it was defective; but I didn't have the time or money to waste on getting a refurbished unit that had the same issue. You should still be able to register the unit, no matter where you purchased it from.
When my FVS-318N showed these issues, I was foolish enough to purchase a new FVS-318Gv2; they use the same circuit board, although I didn't know that at the time.
So now I just look forward to a new firmware in the hope I will one day be able to use these units; till then my ZyXEL VFG6005N firewall does sterling service (with gigabit ports).
- ccloSep 30, 2016Aspirant
Well, I did that GUI reboot it is now over 14 hours... no issues so far... Just keep hoping...
Very promising
However, the problem is a power glitch, when the unit reboots normally.
Well, hope they fix all these bugs on the router... It is a good router... just the firmware is crap.
It runs cool, it runs fast... for 10 mins
- ccloOct 02, 2016Aspirant
Well after 48 hours here is what happen. I set my router to reboot itself inside the GUI at 4:50 AM each monring. The frist 14 hours went fine after I manually did a reboot inside the GUI. On Saturday morning at 4:50am it reboot itself as I programed it, worked fine for 24 hours. Then this (Sunday) morning it again reboot itself as I programed at 4:50am, I came home at 6:30 and my internet light went out! I need to unplug it off the wall and plug it back in.
I do shift work, and I am doing night shift. I was trying to access my VPN around 4:57am, while it is rebooting... maybe that screw it up or something... But I give it more testing run...
But if Netgear reading this! PLEASE GET YOUR ACT TOGETHER! AND RELEASE A GOOD FIRMWARE!!!!!!
I don't know how many router they sell, but this is happen on every FVS318GV2 out there???!?
- shiekhOct 02, 2016Guide
Same problem seen on the FVS318N, but I doubt everyone sees it, as there are some positive reviews on amazon.com
Like you I need the unit to recover gracefully from a power glitch, as I am not always present.
- SamirDOct 02, 2016Prodigy
I have experienced my 318n acting funky when it loses its wan. It also needs a very extended time to boot and start working propertly (at least 30m). This seems to just be the nature of the beast. The two huge drawbacks to these units I've run across is the boot time and the dhcp server, but the pros are that they are pretty solid once up and do provide good throughput.
Well, I have my router about 4 days. My internet usually last 10 hours before it goes out. Not 30 minutes to an hour like you guys. And when my internet goes out, my VoIP still works. Just no internet but my Ooma that connected to Netgear still work while my internet are dead. And of course I can't access my router's GUI then.
Scene I discover my internet went out at 6:30a this morning, it is 1:22p now. That already 7 hours, this is random.
- rickgodeOct 02, 2016Aspirant
That's weird that your internet light goes out after 10 hours. If mine is up for more than 30-45 minutes, it's up until a power outage.
I too have a VoIP phone through charter. Two times last week my internet service went out (I can tell because my phone won’t even work) After 10 minutes my internet service came back and everything was back to normal.
My issue (along with others) is that after a power outage. (I'm actually afraid to reboot) Everything else comes up, except the FVS318Gv2. The internet light will be on and everything will be working for about 5-10 minutes, then the internet light will go out and the only way to access the GUI is after a hard reboot (unplug the router from the wall)
My router is in the house so it's not as big a deal for me to be physically work on it, but others that have this router away from themselves, this becomes a HUGE issue.
I'm sure we will have a brown out or something with the power in the coming months, I'll report my findings of what happens then. Because when mine is up, it works FANTASTIC and the throughput is the entire reason I got this router in the first place.
I still have my FVS336G "in the rack" so that if my FVS318Gv2 doesn't come back up the first time, I can just plug in the FVS336G quickly and everyone at the house will be happy. Too bad its WAN throughput is only 30MBps...
Ricky
Well, it is 23:46, I am at work now... And it is still up and running... I don't know what to say.
- SamirDOct 03, 2016Prodigy
rickgode wrote:My issue (along with others) is that after a power outage. (I'm actually afraid to reboot) Everything else comes up, except the FVS318Gv2. The internet light will be on and everything will be working for about 5-10 minutes, then the internet light will go out...
This sounds exactly like what the 318N does. But what you have to do is wait some more after it stops working and let it completely boot up. I think also that if you try to access too much during its first 'working' phase it may actually mess it up and keep it from booting up completely. At least that's what I've kinda learned about my 318Ns. When they boot up, I don't touch them for at least 30 minutes. After that, they're solid for months.
- ccloOct 03, 2016Aspirant
I look at Amazon reviews. There are 59 good reviews and 45 bad. I say almost 50/50. I don't know how people can gave good review on this thing. I guess they never unplug there unit out of the wall before!
- shiekhOct 03, 2016Guide
This firmware is also used on units other than the FVS318 series, and there it would seem without such aggravation.
I, for one, can't afford to baby my unit up each time it goes down; I need things to be robust and reliable in the face of a power glitch.
And this is exactly why the smb market isn't for 'rock solid reliability'--that's enterprise stuff.
In the smb market, you simply move to another product with a different set of trade-offs that fit you needs better. Why do this? Simple--cost. You could spend 4x the amount on an enterprise unit or go through a couple of different cheaper smb models before you find the one that works.
If I had a lot of DHCP clients jumping on and off the network, the FVS318N would never have worked for my application. But that wasn't a requirement compared to reliability once it booted, which the FVS318N outshined the rv016 which needed a reboot every 24hrs to be stable.
My computers, Wi-Fi, etc are all rock solid, and most were fished out of the trash.
- SamirDOct 04, 2016Prodigy
It's almost completely irrelevant where something came from. If it was built well (enterprise quality), it will still work fine. And for some reasons, while computers and APs seem to not have problems being rock solid, routers regularly do.
- shiekhOct 04, 2016Guide
True, but even the most basic equipment, no matter how cheap, should be able to boot up and work for longer than 10 mins.
I think they actually do, just as my 318n does. It's just that most people won't wait the 30m+ it takes for these to boot up solid.
- shiekhOct 05, 2016Guide
I find that if all is left plugged in, then it doesn't come up even given time; so it is quite a balancing act to get it running.
People that work over the internet can't afford such disruption.
- ccloOct 05, 2016Aspirant
My router ran good for about 3 days... It dead again this morning! This is bull**bleep**! I have it set to reboot on 5:00AM this morning. Preheaps I should take it off! Once the router run good... I shouldn't try to reboot it. I just unplug my router, plug it back in and then did a GUI reboot. This time I took off the self rebooting feature and see how long this last!
Freaking amazing! The router came out over a year... we still a beta tester!
scat? was that the word you were looking for ;-)
- shiekhOct 07, 2016Guide
Actually the FVS-318N (same board and firmware) came out around 2012, and the FVS-318Gv2 around 2015; so one might argue they have had almost 5 years to iron out the bugs.
