dado112233
Nov 22, 2012Aspirant
FVS318N question
hi all, first post :) :) just a short question... i got a FTTH connection the other day and i want to replace their router (Fritz 7930) with FVS318N. As far as i understand the documentati...
jmizoguchi
Nov 22, 2012Virtuoso
You may want to contact support with an issue at my.netgear.com
All the setting should be under network config tab -ipv6 for the WAN so other vlan should be for LAN side
