therealdgh
Apr 23, 2016Aspirant
FVS318N Worth Upgrade to 4.3.3-6?
Hello, I have an FVS318N firewall currently running firmware 4.3.1-22, sitting behind a DSL modem running in bridge mode and for the most part everything is running well. The thing I am wonde...
therealdgh
Apr 24, 2016Aspirant
DaneA,
Thanks for your response.
I assumed that since Netgear listed "No NAT translation of SIP headers during REGISTER, outbound call and SDP" in the known issues section of firmware release notes that anyone running an FVS318N with firmware from 4.3.2-7 on up that also was running VoIP phones would have encountered the issue. One thing I am wondering is if this particular issue only applies if SIP ALG is enabled. If so, then I won't have to worry about it as I have SIP ALG disabled.
Is there any repository or site where we can look up or follow the track of known issues?
My only reason for wanting to upgrade the firmware is to stay current on the security vulnerability fixes.
DaneA
Apr 25, 2016NETGEAR Employee Retired
Hi therealdgh,
It is alright if you want to update the firmware of your FVS318N to the latest v4.3.3-6. Monitor the performance of your FVS318N after updating the firmware. Be reminded to perform a factory reset on the FVS318N after a successful firmware upgrade then reconfigure it from scratch.
I'm afraid that there is no repository or site to track down known issues. However, you may open an online case with NETGEAR Support at anytime if you need technical assistance or if you have encounter something that you think its an issue with the FVS318N.
DaneA
NETGEAR Community Team
