akcw
Jun 21, 2011Aspirant
FVS318v3 Reserved IP Capacity
Running a FVS318v3 with 3_0_28 firmware. DHCP range 192.168.20.2 thru 192.168.20.253. I seem to be able to only configure 24 reserved IP addresses. When attempting the 25th reserved address the FVS31...
Glitched
Jun 27, 2011Aspirant
Tested and can not reproduce. I was able to do 30 reserved addresses(got bored so I didn't go any further).
What else do you have configured? Firewall rules, if so how many? VPN tunnels, if so how many? What is the size of your DHCP pool?
Also this device is designed for a network of no more than 10 users...that would be 10 very low traffic users. Any more than that you're really pushing the limits of this unit and probably will be experiencing problems.
- Feb 20, 2022Retired_Member
