akcw
Jun 21, 2011Aspirant
FVS318v3 Reserved IP Capacity
Running a FVS318v3 with 3_0_28 firmware. DHCP range 192.168.20.2 thru 192.168.20.253. I seem to be able to only configure 24 reserved IP addresses. When attempting the 25th reserved address the FVS31...
Glitched
Sep 14, 2011Aspirant
One thing to keep in mind about the FVS318 is that it was manufactured and designed in about 2002-2003. The hardware is very much so out of date and only supports 5,000 concurrent sessions at any time. In a network that size I highly recommend getting a newer router such as the FVS338 or FVS336gv2 which would be able to handle what you're trying to do much better
- Feb 20, 2022Retired_Member
