Christophe1376
Oct 05, 2014Aspirant
FVS336GV2 - Handling of VPN IPSec tunnel and DMZ
Hello all. I have some problems with the handling of VPN and DMZ rules. Here is my configuration 1 location A, with public IP AA.BB.CC.DD Router NETGEAR FVS336GV2, Firmware 4.3.1.18 LAN 192...
Christophe1376
Oct 06, 2014Aspirant
Ok Adit, i'll do that.
But i've set up these rules, because only with DMZ port enabled, i was not able to browse internet from the Wifi access point.
I can connect on the access point, receive a LAN IP adress from the router, i can ping the router from the DMZ LAN, but no access to internet
And just after setting up these 2 rules, it was OK for the DMZ internet access.
Maybe i've done something wrong. I'll check that tomorrow envening and keep you updated
Angain thank you.
kind regards
Angain thank you.
kind regards
