gmork123's avatar
gmork123
Follower
May 07, 2012
FVS336GV2 load balancing with auto rollover
Hi,
Just received a FVS336GV2 to try if it's suitable to replace my linux router.
If I configure it with load balancing, will it detect line problems on one of the lines and route everything over the other line in such a situation?
If it does, I'm wondering how it would find out if one of the lines is dead, because I cannot configure WAN failure detection IP's in load balancing mode.
Hope somebody can answer this, otherwise I will have to try to setup some test situation.
Thanks! Wessel
  • I will move the traffice to other WA Nwhen it drops the connection. You need to test out by unplug the WAN
ProSupport for Business
