SWILLIS
Mar 02, 2017Aspirant
FVS336Gv3 locks up and sometimes reboots
Hi i have 3 fvs336gv3 routers all running 4.3.4-2 firmware these units are running vpn's with each other in a star configeration. i have one that is locking up/rebooting several times a day all ...
JohnRo
Mar 06, 2017NETGEAR Employee Retired
Hello SWILLIS,
Welcome to the community!
Did the issue occur after you have upgraded the firmware to 4.3.4-2 or has it been having issues ever since? Did you perform a factory reset after updating the firmware?
Thanks,
JohnRo
Mar 07, 2017NETGEAR Employee Retired
Hi SWILLIS,
It appears that the firewall experiences the issue under heavy load. Since you have already performed a hardware reset and updated the firmware a few times it is looking like a hardware issue is on the way. I suggest to contact support, it might need to be looked at further or be replaced.
Thanks,
- SWILLISMar 08, 2017Aspirant
ok i will talk to to suport
