Guardian2100
Jan 06, 2016Guide
FVS336Gv3 SSLVPN
Hi, We have a working firewall (FVS336Gv3) up and running. We have configured SSLVPN as stated in the manual. Everything is working good. But it's only accessible by IP-adress (in wind...
- Jan 08, 2016
Hi,
Thank you for replying.
This worked for me. Thanks for the solution.
JohnRo
Jan 06, 2016NETGEAR Employee Retired
Hello Guardian2100,
Welcome to the community!
May I please know what firmware version you are using on the firewall? I know I have seen a question like this before but I cannot tell if that have been addressed.
Looking forward to your response.
Thanks,
Guardian2100
Jan 07, 2016Guide
Hi,
Thank you for answering so fast.
This is the firmware version: 4.3.3-6
- JohnRoJan 07, 2016NETGEAR Employee Retired
Hi Guardian2100,
It appears that you are already using the latest firmware version. Can you try using your local DNS server for the SSL-VPN tunnel? See image reference below:
I hope this helps, let us know.
Thanks,
- Guardian2100Jan 08, 2016Guide
Hi,
- JohnRoJan 08, 2016NETGEAR Employee Retired
Hello Guardian2100,
I am glad it worked out for you!
Thanks,
