Guardian2100
Jan 06, 2016Guide
FVS336Gv3 SSLVPN
Hi, We have a working firewall (FVS336Gv3) up and running. We have configured SSLVPN as stated in the manual. Everything is working good. But it's only accessible by IP-adress (in wind...
- Jan 08, 2016
Hi,
Thank you for replying.
This worked for me. Thanks for the solution.
Guardian2100
Jan 07, 2016Guide
Hi,
Thank you for answering so fast.
This is the firmware version: 4.3.3-6
JohnRo
Jan 07, 2016NETGEAR Employee Retired
Hi Guardian2100,
It appears that you are already using the latest firmware version. Can you try using your local DNS server for the SSL-VPN tunnel? See image reference below:
I hope this helps, let us know.
Thanks,
- Guardian2100Jan 08, 2016Guide
Hi,
- JohnRoJan 08, 2016NETGEAR Employee Retired
Hello Guardian2100,
I am glad it worked out for you!
Thanks,
