tompar
Sep 02, 2016Aspirant
FVS336Gv3 VPN GRE Problem
Hi, We upgraded from our old Netgear Prosafe FVS 338 to this years "NETGEAR ProSafe™ Gigabit Dual WAN SSL VPN Firewall FVS336Gv3". Our problem is that the VPN dosent work from "outside" our netw...
- Sep 08, 2016
Hi tompar,
I'm glad to know that L2TP works fine. Based from your answers, it seems that PPTP should be working. With regard to this, if ever you still want to use PPTP, I suggest you to open an online case with NETGEAR Support for further assistance for the FVS336Gv3 to be checked.
DaneA
NETGEAR Community Team
DaneA
Sep 05, 2016NETGEAR Employee Retired
Hi tompar,
Welcome to the community! :)
It seems that you have a PPTP VPN configured on the FVS336GV3. Kindly access the articles below and it might help:
Configuring a PPTP VPN Tunnel to ProSAFE/ProSECURE routers
How to Connect Windows Computer to NETGEAR PPTP Server
DaneA
- tomparSep 05, 2016Aspirant
Hi,
That might work but we do use our Windows Server 2008 to handle the user logins using AD domain.
As I said, it works fine within the network, and the port is forwarded correctly to the windows server computer (PPTP forwards to 192.168.0.100)
But when we try from outside our network, it says that GRE is a problem.
This works fine on our old router.
Thomas
- DaneASep 07, 2016NETGEAR Employee Retired
Hi tompar,
Since the problem occurs from “outside” the network, kindly check the Internet IP address used in the client side PPTP configuration if correct since the FVS336Gv3 was installed. Do you have a static Internet IP Address or are you using a DDNS type service? It is possible that the settings no longer matches the old FVS338 and could prevent the connection from “outside”.
You could enable logging temporarily on the WAN inbound to see if the PPTP client is actually hitting the firewall when initiating the PPTP VPN. This would also help to know if the Internet IP address is set correctly or not.
You also mentioned that when it works from inside the network the (PPTP forwards to 192.168.0.100), did you set the correct inbound firewall rule to pass traffic coming from the WAN onto the Server at 192.168.0.100? – again enabling and checking the inbound firewall rule logs can help determine if the traffic is hitting the firewall and being forwarded to the correct IP address.
What is the exact error message when the PPTP client fails to connect? It would be best that you post a screenshot or image of it.
DaneA
- tomparSep 08, 2016Aspirant
"Since the problem occurs from “outside” the network, kindly check the Internet IP address used in the client side PPTP configuration if correct since the FVS336Gv3 was installed. Do you have a static Internet IP Address or are you using a DDNS type service? It is possible that the settings no longer matches the old FVS338 and could prevent the connection from “outside”."
Its the correct IP / hostname, i see the connection in the log.
Firewall dont block anything, i've checked the logs
It forwards correctly, i see the logs it's connecting to the correct server.
This is the RasMan events from Event viewer, as you see the problem is with GRE.
The strange thing is this works fine with our old Netgear Prosafe.
I've tried LPTP instead of PPTP and that works fine. So i might use that instead, but then it seems i've cant use the AD at 192.168.0.100 as user authentication, i have to create the users in ProSafe.
Thanks for response.
Tom
