tompar
Sep 02, 2016Aspirant
FVS336Gv3 VPN GRE Problem
Hi, We upgraded from our old Netgear Prosafe FVS 338 to this years "NETGEAR ProSafe™ Gigabit Dual WAN SSL VPN Firewall FVS336Gv3". Our problem is that the VPN dosent work from "outside" our netw...
- Sep 08, 2016
Hi tompar,
I'm glad to know that L2TP works fine. Based from your answers, it seems that PPTP should be working. With regard to this, if ever you still want to use PPTP, I suggest you to open an online case with NETGEAR Support for further assistance for the FVS336Gv3 to be checked.
DaneA
NETGEAR Community Team
tompar
Sep 08, 2016Aspirant
"Since the problem occurs from “outside” the network, kindly check the Internet IP address used in the client side PPTP configuration if correct since the FVS336Gv3 was installed. Do you have a static Internet IP Address or are you using a DDNS type service? It is possible that the settings no longer matches the old FVS338 and could prevent the connection from “outside”."
Its the correct IP / hostname, i see the connection in the log.
You could enable logging temporarily on the WAN inbound to see if the PPTP client is actually hitting the firewall when initiating the PPTP VPN. This would also help to know if the Internet IP address is set correctly or not.
Firewall dont block anything, i've checked the logs
You also mentioned that when it works from inside the network the (PPTP forwards to 192.168.0.100), did you set the correct inbound firewall rule to pass traffic coming from the WAN onto the Server at 192.168.0.100? – again enabling and checking the inbound firewall rule logs can help determine if the traffic is hitting the firewall and being forwarded to the correct IP address.
It forwards correctly, i see the logs it's connecting to the correct server.
What is the exact error message when the PPTP client fails to connect? It would be best that you post a screenshot or image of it.
This is the RasMan events from Event viewer, as you see the problem is with GRE.
The strange thing is this works fine with our old Netgear Prosafe.
I've tried LPTP instead of PPTP and that works fine. So i might use that instead, but then it seems i've cant use the AD at 192.168.0.100 as user authentication, i have to create the users in ProSafe.
Thanks for response.
Tom
DaneA
Sep 08, 2016NETGEAR Employee Retired
Hi tompar,
DaneA
