24mediaAdmin
Jul 24, 2017Guide
FVS336Gv3 WAN-LAN Throughput
Hello,
I'm Netgear Powershift Partner and got a serious problem with the low WAN-LAN throughput of the FVS336Gv3. I expected up to 350Mbit/s as promised in the datasheet. My Internet Connection is Fibre with 150MBit and PPoE. The router is not able to get above 44-45MBit/s. Nearly every setting is off. There is no logging, no filter, just a few portforwardings. Newest Firmware 4.3.5-3 (older ones also doesn't work)
Maybe someone of the professionals can explain, why a nearly 300,- Euro professional Firewall Router is not able to get acceptable download speeds where a 30 euro cheap WNDR3700v4 can reach our 150MBit easily.
I really don't know what to do. How should we explain this behaviour to our customers?! The solution can not always be to buy an SRX5308.
Please, is there anything we can test or do about this silly problem?
Regards, Rudolf
Update:
I now contacted Support directly. Recommendation was to connect another router between fiber modem and FVS336Gv3 and create double NAT to test if speed increases. Test was good, we reached 150MBit. But that can't be an acceptable solution for us and our customers. Let's see what happens next...
...as expected, support told me there will not be any new Firmware Update because FVS336Gv3 is END OF LIFE as all other Netgear Prosafe(VPN) and Prosecure(UTM) Firewalls.
- DaneANETGEAR Employee Retired
Hi 24mediaAdmin,
I appreciate that you shared here in the community how did your support ticket with NETGEAR Support goes. Your concern seems to be similar on the forum thread here wherein it was mentioned that the problem is also present on other brand (such as Cisco) and the workaround recommended is to connect another router (or switch) in between the modem and the ProSAFE firewall which is the same workaround recommended to you.
DaneA
NETGEAR Community Team
