stagethen
Nov 15, 2016Aspirant
FVS336Gv3 with vDSL (German Telekom) and a ZyXEL Modem
Hi Community, i got a VPN Router with ADSL 16000 from the German Telekom in use. WAN1. No problems with that. Now my Provider gives me the possibility to use ADSL *and* vDSL (WAN2) - so i bou...
DaneA
Nov 24, 2016NETGEAR Employee Retired
Hi stagethen,
Welcome to the community! :)
Let us isolate the problem. Kindly try to connect the VDSL modem (Zyxel) to the WAN 1 port of FVS336Gv3. Set the WAN 1 port of the FVS336Gv3 as the only active WAN connection. Observe what happens.
Let us know the results.
DaneA
NETGEAR Community Team
- stagethenNov 24, 2016Aspirant
Meanwhile, the Problem is solved after many days of trouleshooting.
I a short overview:
> German vDSL uses vLAN 7 and 8.
> Netgear cant handle vLAN on the WAN Ports.
> You need a modem wich can untag the communication asnd tag it while it is going to the internet.
> the Priority settings must set to zero
That's it.
- DaneANov 24, 2016NETGEAR Employee Retired
Hi stagethen,
I am glad to know that the problem is now solved. :) What you have just shared would be helpful to other community members.
Since the problem has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
