lightknightrr
Nov 22, 2016Tutor
Getting SRX5308 VPN IPSec to work with Android (when using DynDNS)
Greetings, It appears that I can achieve a IPSec VPN Connection (both the Android device and the SRX5308 (with the latest firmware) confirm it), but there appears to be no traffic flowing through...
- Jan 12, 2017
Questions, comments, difficulties?
DaneA
Dec 14, 2016NETGEAR Employee Retired
Awesome! :) This would help a lot of community members.
I encourage you to mark the most appropriate post / reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
lightknightrr
Jan 12, 2017Tutor
Finally made it to Starbucks. Tried out the ShrewSoft client with Mint 18.1 (I think we are up to 18.1) and Windows 10 Pro (both 64-bit, Windows 10 was a VM in VirtualBox).
Anyway, these settings should be consistent with everything else up until now (same shared key, same username, same password, etc.).
If you are on Windows, here's the link to the ShrewSoft VPN client: https://www.shrew.net/download/vpn . It's free.
So, General Settings are above, really only need to fill in your (possibly DynDNS) hostname.
- lightknightrrJan 12, 2017Tutor
Client settings. I disable / uncheck the 'Enable Client Login Banner' box.
Name Resolution: I keep this as is.
Just a side note: the Windows client has WINS settings in addition to DNS settings. I keep them as is.
Authentication Method: What method are we using? X-Authentication with a Private Shared Key. Mutual PSK + XAuth in other words.
Local Identity: It's going to be a FQDN, and we've been using "remote.com" thus far, so "remote.com" it is.
Remote Identity: IP Address. 'Use discovered remote host address' should be checked.
Once again, these settings should match the IKE Policy & friends settings from way earlier. No surprises.
Pre-shared Key: It's going to be the same one you created earlier. Don't email it, text it, instant message it, or pass it in anyway over unencrypted electronic communications: it defeats the purpose of having a PSK.
Copy the PSK by hand. Input it by hand. Well, for anything important.
Exchange Type: Aggressive (should be the default)
DH Exchange: We are using 'Group 5', because we prefer our encrypted communications to stay that way.
Cipher Algorithm: AES (best choice, from earlier)
Cipher Key Length: 256 bits (longer is usually better, again this just reflects our settings from earlier)
Hash Algorithm: SHA1 (best choice, from earlier)
Key Life Time Limit: 28800 Secs (to match what we already have in place)
Transform Algorithm: ESP-AES
Transform Key Length: 256 Bits
HMAC Algorithm: SHA1
PFS Exchange: Group 5
Again, these settings just mirror the IKE Policy & friends.
Policy:
I uncheck 'Obtain Topology Automatically or Tunnel All' (should allow creation of a split tunnel). Then I add the subnet (192.168.1.0) + subnet mask (255.255.255.0) for the network that I am interested in under Remote Network Resources.
Click 'Save', and your configuration should appear in the Shrew Soft VPN Access Manager.
Click the 'Connect' button or double-click the lock icon, and you will be asked for your username and password. Put in the appropriate values (one of the IPSec VPN User accounts you created earlier). In a few moments, it should say something to the effect that the tunnel is established (in a little log window). If not, the information from its little log window can help you figure out what's causing the connection error.
And if you are running Linux Mint / Ubuntu / Debian / any number or flavors of linux distros out there, install this (through your appropriate package manager...or compile it from a tarball if that's how you roll):
And this:
You don't need to install this, but you might want to if you are trying to track down some problems (this offer without warranty):
