Six_Feet_Under's avatar
Apr 16, 2016
How to configure simple Port Forward on FVS318N
This should be simple, but I struggled with it for a while.  Can't find the instructions in the manual.  "Port Forwarding" is not obvious in the menus.
Here's the trick.  It requires three seperate entries on the router, not just one.
You must create a Security>Services>Custom Services Table
then Create Security> Firewall>LAN WAN Rules for both Outbound and Inbound Services
hope this helps...
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Six_Feet_Under,
    Welcome to the community! :)
    Thanks for sharing.  This will help other forum users looking for such steps.
    Cheers,
    DaneA
    NETGEAR Community Team
ProSupport for Business
