tmorse's avatar
tmorse
how to move one VPN lic to anther pc?
Every time i try to lic VPN client software says lic's all used. Where is the portal or instrucions on how to release used lic that no longer have. So it can be used again.  Have not found out where ...
  • JohnRo's avatar
    JohnRo
    Dec 07, 2016
    Hi tmorse,
    I viewed the ticket that was opened when you have contacted our support team, you were given a number to call but I was not sure how you were not able to get hold of them. I have personally forwarded the license reset request to our higher tier support. Both licenses should have been reset by now and you should be able to use it on all 10 clients.
    Let me know if this helps. We apologize for the inconvenience.
    Thanks,
ProSupport for Business
