LAK1
Jan 09, 2019Aspirant
IPSEC VPN ACCESING THROUGH COMPUTER NAME
Hello,
I´ve configured a IPSEC VPN with UTM 50 and netgear ProSafe VPN Client.
The VPN is ok and I can acces to all computers by using the IP Address but there are 2 server that I need a...
JohnC_V
Jan 11, 2019NETGEAR Employee Retired
Hi LAK1,
Welcome to our community! :)
It is possible to use the host name if you do have an active directory on your remote site. The Active Directory will be the one that will resolve the host name from LAN as host name resolution is not supported over VPN.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
