PopinatorWV
May 09, 2016Aspirant
IPSec VPN tunnel between SRX5308 and a FVS336Gv3 suddenly changes to a SSLVPN tunnel
I had an IPSec VPN tunnel between a SRX5308 router and a FVS318G router had to change the FVS318G router went to a FVS336Gv3 router. Set up the IPSec VPN tunnel on the 336Gv3 router and all was fine ...
- May 19, 2016
Hi PopinatorWV,
For the logs to be analyzed, I advise you to open an online case with NETGEAR Support at anytime. State your concerns and attach the logs on the online case you have opened. The online case will be forwarded to the engineering team to be analyzed.
DaneA
NETGEAR Community Team
DaneA
May 10, 2016NETGEAR Employee Retired
Hi PopinatorWV,
For me, it is very unlikely for the IPSec VPN setup to suddenly switch to SSL VPN setup without having a person reconfigure the settings of both firewall(s). Are you the only person that has access to both firewall(s)?
To re-establish the IPSec VPN tunnel, you will need to reconfigure everything. Otherwise, if ever you have backed-up the configuration of both firewall(s) when IPSec VPN was working fine, then you may just restore the configuration file to the firewall(s).
Both IPSec VPN and SSL VPN have their own advantages depending on the requirements of the network or client(s). Personally, I prefer IPSec VPN since I find it easier to set it up.
DaneA
