PopinatorWV
May 09, 2016Aspirant
IPSec VPN tunnel between SRX5308 and a FVS336Gv3 suddenly changes to a SSLVPN tunnel
I had an IPSec VPN tunnel between a SRX5308 router and a FVS318G router had to change the FVS318G router went to a FVS336Gv3 router. Set up the IPSec VPN tunnel on the 336Gv3 router and all was fine ...
- May 19, 2016
Hi PopinatorWV,
For the logs to be analyzed, I advise you to open an online case with NETGEAR Support at anytime. State your concerns and attach the logs on the online case you have opened. The online case will be forwarded to the engineering team to be analyzed.
DaneA
NETGEAR Community Team
