PopinatorWV
May 09, 2016Aspirant
IPSec VPN tunnel between SRX5308 and a FVS336Gv3 suddenly changes to a SSLVPN tunnel
I had an IPSec VPN tunnel between a SRX5308 router and a FVS318G router had to change the FVS318G router went to a FVS336Gv3 router. Set up the IPSec VPN tunnel on the 336Gv3 router and all was fine ...
- May 19, 2016
Hi PopinatorWV,
For the logs to be analyzed, I advise you to open an online case with NETGEAR Support at anytime. State your concerns and attach the logs on the online case you have opened. The online case will be forwarded to the engineering team to be analyzed.
DaneA
NETGEAR Community Team
DaneA
May 11, 2016NETGEAR Employee Retired
Hi PopinatorWV,
I've just read your message. Kindly keep us posted. :)
DaneA
PopinatorWV
May 13, 2016Aspirant
Hello again all,
Well I tried what was suggested to no avail. I was able to get the IPSec VPN tunnel up again only thing is that the SSL VPN was also still up. After about an hour or so I checked the on line status of the IPSec and found it was disconnected and the SSL VPN was active and connected. I even went so far as to manualy re-configure both the SRX5308 and the FVS336Gv3 routers same exacxt thing happened again. Is there a way to turn off the SSLVPN or not? How difficult is the SSLVPN to set up, and do I need an SSL certificate for each router? I really need to get this tunnel established and working properly ASAP. Thank you in advance for your assistance.
- DaneAMay 15, 2016NETGEAR Employee Retired
Hi PopinatorWV,
Kindly post image(s) or screenshot(s) that shows the IPSec VPN suddenly switches to SSL VPN on both SRX5308 and FVS336Gv3.
DaneA
NETGEAR Community Team- PopinatorWVMay 18, 2016Aspirant
Hello All again,
I have had some new developements in this issue I am having. The SSLVPN seems to be on all the time. I can initate the IPSec VPN tunnel and after a while it stops and the only thing showing is the SSLVPN connection. Is there a way to stop the SSLVPN connection? I have tried to DISCONNECT the SSLVPN from both routers but it will not disconnect. Each time I try I am sent back to the log on screen saying my session has expired and I need to log back in. I have tried this on both Routers and get the same responce. If I DISCONNECT the IPSec tunnel it disconnects it like it should. then I can also re-establish the IPSec tunnel.
I have a logfile of the IPSec VPN connections and it shows, at least to me, that the IPSec all of a sudden breaks the connection and cannot re-establish it. Do you need me to post the log or a portion of it? Please let me know and I will post it. Again thanks for your assistance
- DaneAMay 19, 2016NETGEAR Employee Retired
Hi PopinatorWV,
DaneA
