PopinatorWV
May 09, 2016Aspirant
IPSec VPN tunnel between SRX5308 and a FVS336Gv3 suddenly changes to a SSLVPN tunnel
I had an IPSec VPN tunnel between a SRX5308 router and a FVS318G router had to change the FVS318G router went to a FVS336Gv3 router. Set up the IPSec VPN tunnel on the 336Gv3 router and all was fine ...
- May 19, 2016
Hi PopinatorWV,
For the logs to be analyzed, I advise you to open an online case with NETGEAR Support at anytime. State your concerns and attach the logs on the online case you have opened. The online case will be forwarded to the engineering team to be analyzed.
DaneA
NETGEAR Community Team
PopinatorWV
May 13, 2016Aspirant
Hello again all,
Well I tried what was suggested to no avail. I was able to get the IPSec VPN tunnel up again only thing is that the SSL VPN was also still up. After about an hour or so I checked the on line status of the IPSec and found it was disconnected and the SSL VPN was active and connected. I even went so far as to manualy re-configure both the SRX5308 and the FVS336Gv3 routers same exacxt thing happened again. Is there a way to turn off the SSLVPN or not? How difficult is the SSLVPN to set up, and do I need an SSL certificate for each router? I really need to get this tunnel established and working properly ASAP. Thank you in advance for your assistance.
DaneA
May 15, 2016NETGEAR Employee Retired
Hi PopinatorWV,
Kindly post image(s) or screenshot(s) that shows the IPSec VPN suddenly switches to SSL VPN on both SRX5308 and FVS336Gv3.
DaneA
