PopinatorWV
May 09, 2016Aspirant
IPSec VPN tunnel between SRX5308 and a FVS336Gv3 suddenly changes to a SSLVPN tunnel
I had an IPSec VPN tunnel between a SRX5308 router and a FVS318G router had to change the FVS318G router went to a FVS336Gv3 router. Set up the IPSec VPN tunnel on the 336Gv3 router and all was fine ...
- May 19, 2016
Hi PopinatorWV,
For the logs to be analyzed, I advise you to open an online case with NETGEAR Support at anytime. State your concerns and attach the logs on the online case you have opened. The online case will be forwarded to the engineering team to be analyzed.
DaneA
NETGEAR Community Team
PopinatorWV
May 18, 2016Aspirant
Hello All again,
I have had some new developements in this issue I am having. The SSLVPN seems to be on all the time. I can initate the IPSec VPN tunnel and after a while it stops and the only thing showing is the SSLVPN connection. Is there a way to stop the SSLVPN connection? I have tried to DISCONNECT the SSLVPN from both routers but it will not disconnect. Each time I try I am sent back to the log on screen saying my session has expired and I need to log back in. I have tried this on both Routers and get the same responce. If I DISCONNECT the IPSec tunnel it disconnects it like it should. then I can also re-establish the IPSec tunnel.
I have a logfile of the IPSec VPN connections and it shows, at least to me, that the IPSec all of a sudden breaks the connection and cannot re-establish it. Do you need me to post the log or a portion of it? Please let me know and I will post it. Again thanks for your assistance
DaneA
May 19, 2016NETGEAR Employee Retired
Hi PopinatorWV,
DaneA
