franck_martin2
May 29, 2013Aspirant
IPSec VPN with SRX5308
Hi everyone, I bought recently a SRX5308 firewall. I want to achieve a Client to Gateway IPSec VPN with this device. I used the VPN Wizard to configure the Gateway and I installed the Netgear VPN P...
franck_martin2
IPsec tunnel will only uses local internet traffic for http etc
This means that client http requests cross the VPN tunnel ?
IPsec tunnel will not resolves PC name via tunnel unless you use modeconfig with own DNS server
So, I have to use modeconfig if I want to go on Internet while tunnel is open ?
IPsec needs 2x public and 2x private with BOTH side different LAN subnet (ex, 192.168.50.x and 192.168.60.x)
It's already done. I also created a static route between the gateway and the client.
