franck_martin2
May 29, 2013Aspirant
IPSec VPN with SRX5308
Hi everyone, I bought recently a SRX5308 firewall. I want to achieve a Client to Gateway IPSec VPN with this device. I used the VPN Wizard to configure the Gateway and I installed the Netgear VPN P...
franck_martin2
I will explain what I did in the following lines:
1. I created the VPN policy with the VPN Wizard:
2. I installed on a Windows 7 PC the Netgear Prosafe VPN client.
3. I clicked on "Configuration" and "Configuration assistant".
4. I answered all questions on the assistant.
5. On the Netgear client:
6. I created some static routes between the gateway and the client and between an host in the remote LAN and the client.
I clicked on "VPN Client".
I entered a connection name and a pre-shared key.
I entered two FQDN for remote client and gateway.
I clicked on "Apply".
I entered an IP address for the client which is included in the remote LAN IP address range.
I entered the remote LAN IP address and mask.
I entered the gateway IP address for the DNS field.
