franck_martin2
May 29, 2013Aspirant
IPSec VPN with SRX5308
Hi everyone, I bought recently a SRX5308 firewall. I want to achieve a Client to Gateway IPSec VPN with this device. I used the VPN Wizard to configure the Gateway and I installed the Netgear VPN P...
jmizoguchi
May 29, 2013Virtuoso
franck_martin2 wrote: I will explain what I did in the following lines:
I used the "VPN Wizard" to create the VPN configuration. I choosed "VPN Client", I entered a name and a pre-shared key for the connection, a FQDN for the remote host and the gateway. I clicked on "Apply".
Then, I installed Netgear Prosafe VPN client on a Windows 7 computer. I entered the gateway's public IP, the pre-shared key and the two FQDN in the reserved fields.
Then, I entered an IP address which is in the remote LAN IP address range for the client, the network LAN address and mask. I used the gateway address for the DNS server field.
I created a static route on the gateway which destination is the client, a static route on a computer of the remote LAN which destination is the client and two static routes on the clients which go to the gateway and to the remote LAN host.
This setup ONLY allows to access server, shared files etc while you will NOT have any internet taffic to surf via SRX while remote user is connected. It will use local internet where user is connected for surfing the internet
if you want ALL traffic go ONLY via tunnel including internet (surfing for user) then you need to use SSL-VPN tunnel (no IPsec) with full tunnel (no split tunnel)
