franck_martin2
May 29, 2013Aspirant
IPSec VPN with SRX5308
Hi everyone, I bought recently a SRX5308 firewall. I want to achieve a Client to Gateway IPSec VPN with this device. I used the VPN Wizard to configure the Gateway and I installed the Netgear VPN P...
jmizoguchi
Jun 04, 2013Virtuoso
will not work.
You have too many IP
this will NOT work. remote needs different even modeconfig used
Give you and idea how it should setup
192.168.1.240 /28
Remote LAN IP: 192.168.1.0 /24
http://vpncasestudy.com/casestudy/FVX538/v1649/casestudy.html
ProSafe FVS318v24 using FVX538 behind Router (Static IP and Dynamic IP)
FVX538 <->FVS318FVS318V24
