bzness
Jul 23, 2017Aspirant
Is there a good explanation of vpn options?
I am working my way through setiing up a VPN tunnel, and I am a bit stymied by the whole process. Is there a good explanation somewhere how this all works on my netgear router? Let's take for example...
DaneA
Jul 25, 2017NETGEAR Employee Retired
Hi bzness,
Kindly access the link below and read the articles listed on the page:
Also, further information can be found on pages 201-299 of the SRX5308 reference manual here about Virtual Private Networking Using IPSec & L2TP Connections and Virtual Private Networking Using SSL Connections.
DaneA
NETGEAR Community Team
DaneA
Jul 30, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
