fredouilmkm
May 27, 2012Aspirant
last firmware DGFV338, where ?
Hi I currently have a DGFV338, which crash each time I send an email with large attachment. I have updated it to the last firmware available (3.05-24 / A.00.62 ) without much improvement. For...
Marto731
Jul 18, 2012Aspirant
To reply to fredouilmkm,
I work in Netgear support. I didn't hear that the last Beta works for a large email attachment instance that you refer to. But you can contact Netgear support in your country.
Rev 64 for the DSL board, is in reference to a disconnections issue with ADSL 2.
To reply to Rolo, the modem (DM111P ) allows you to connect into WAN port,
and not DSL. If you want Dual WAN, then contact Tech support, and they will advise re replacement. You may be asked for original proof of purchase, as this is a warranty condition.
For you both, there have been alot of happy customers with this device in recent years. As June has pointed out, it is under lifetime warranty. But it is end of life, and technology has progressed.
Marto,
Netgear Tech support
Marto,
