jennylynn89's avatar
jennylynn89
Letter of Volatility SRX5308-100NAS
Hi,
Where can I find the letter of volatility for:
SRX5308-100NAS (FIREWALL, SSL VPN, PROSAFE QUAD WAN)?
Thank you,
Jenny
  • Hello jennylynn89,
    Welcome to the community!
    You can download the LOV for SRX5308 on this link. Let us know if you need anything else.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello jennylynn89,
    Thanks,
      • JohnRo's avatar
        JohnRo
        Hi jennylynn89,
        You are welcome! If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
        Thanks,
    • DaneA's avatar
      DaneA
      jennylynn89
      If you were able to download the Letter of Volatility for the SRX5308 , we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      DaneA
      NETGEAR Community Team
ProSupport for Business
