ajm_ch
Apr 21, 2016Aspirant
Load balancing issue with SRX5308 - address not found
I haven't been able to use load balancing for weeks now. If I do, it works for a while and then (most) websites just don't load any longer. It can be just any address, also parts of a website (eg ima...
- May 01, 2016
Well, it won't be solved. Patience left me. Level 2 said that Level 3 made some tests and didn't find anything wrong.
I changed my set-up so that I won't need the SRX any longer. Case closed.
Thank you for your help. All the best.
Alain
JohnRo
Apr 29, 2016NETGEAR Employee Retired
Hello ajm_ch,
I'll look up your case also. Hope it will be fixed soon. :)
Thanks,
ajm_ch
May 01, 2016Aspirant
Alain
