MarkWHolbrook
Oct 01, 2015Aspirant
Multi homed network not going through ipsec vpn
I have a srx-5308 VPN firewall with an lan network 10.10.10.0/24. To IPsec VPN to another site I need to either re-ip the entire network or use a new network such as a multi home network to 10.100.10.0/24. The reason is the second office already has a vpn to a network that is the same IP scheme as mine.
I have added a multi home network 10.100.10.0/24 and computers with this IP scheme can connect to the internet. The VPN is working from the remote site to a computer with this IP scheme. However the traffic from my network on the multi home 10.100.10.0/24 network does not seem to go through the VPN.
Is there any way to send a multi homed network though a IPSec VPN connection? Thanks, Mark
- MarkWHolbrookAspirant
And another strange piece of data, the remote site can ping my 10.100.10.0/24 compter over the VPN but I cannot ping there the remote site.
Problem solved. I made the main network 10.100.10.0/24 and the multi home network 10.10.10.0/24. Both networks can get on the internet and the IPsec VPN works over the main network. Thanks to me for figuring this out as no one commented on this post.
- SamirDProdigy
Glad you figured it out. I was going to say that the easiest way would have been to just change the home network, but sometimes that's not the easiest way for other reasons.
