GreenHornet5
Mar 21, 2012Aspirant
Multiple LANs on 1 WAN
Hi all, I have performed a search but cant seem to find what I am looking for. Current Set up 2wire BT router set up as DCHP on a peer-peer network. Previous IT guy set up IP address as 192....
jmizoguchi
Mar 21, 2012Virtuoso
I have the BT router set up with PPPoE and all the login and user passwords etc. This IP address is set to 192.168.69.1 and is the DHCP server for all the PC's on the peer-peer network.
mistake here
you need PPPoE authentication at FVS.
