Elgand
Dec 13, 2017Aspirant
NAT within VPN
Hello, Corporate wants to create a VPN connection between their office and our satellite office. The VPN is connecting through stage one, but traffic is not appearing how they want it to appear a...
Elgand
Dec 17, 2017Aspirant
This is a Box to Box VPN. The VPN we have established is via IPsec.
JohnC_V
Dec 18, 2017NETGEAR Employee Retired
May I know if both ends are using Netgear firewalls? You may try to follow this article in order to work your VPN connection.
- ElgandDec 18, 2017Aspirant
Hello,
No, both sides are not utilizing Netgear boxes. The other end is our corporate office and they are using Check Point NGX R77.30 Model 23500.
We requested a subnet and are going that route rather than using a NAT'd address to enter the tunnel. All of my searching has resulted in no concrete answer on whether this is even possible with the FVS336Gv3.
- JohnC_VDec 19, 2017NETGEAR Employee Retired
Elgand,
It is not possible to create a VPN connection using a NAT'd address on a FVS336Gv3, as it cannot find the NAT'd address on a public network without the WAN IP.
