readingna
Nov 28, 2018Aspirant
Need ProSafe SP-Lite VPN Client License Key Reset for Netgear DEVG-2020
Good morning,
We are using a Netgear DEVG-2020 Modem/Router purchased from Telstra as part of their DoT small business solution. It came with 5 ProSafe SP-Lite VPN Software for remote access....
- Dec 13, 2018
We are able to reset all the 5 licenses as per your request. You may now try to install the key.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
jjnick1952
Jan 10, 2019Aspirant
Subject: RE We are able to reset all the 5 licenses as per your request. You may now try to install the key.
Hello
I CANNOT CREATE A NEW THREAD - FAILURE NOTICE
Thank you for your prompt reply. The one Licence key that I know the number of is in use. How can i find out the key numbers of the other4 that you have reset.
Regards
John
