njbrown21
Jul 19, 2019Aspirant
Netgear BR500 - VPN & Wireless
Hi, I an soon to be moving to Brunei and want to be able to access australian content on multiple devices so I recently purchased the insight instant VPN router. I am however not sure as to whether i...
DaneA
Jul 22, 2019NETGEAR Employee Retired
Welcome to the community!
Does anyone know whether i can setup a VPN (i.e. NordVPN or PIA) on this router?
You can use OpenVPN. The guaranteed OpenVPN throughput with BR500 is at least 50mbps.
Also I will require wifi and have a wifi router, am i able to connect this wifi router to the BR500 that will allow anyone connected to the wifi network to access the VPN without individual logins?
The BR500 does not have the capability to provide a wireless network. If you will connect a wireless router to the BR500, I suggest you to set the wireless router as a standalone access point. Since the BR500 is already a router and you will connect a wireless router behind it, you will have a Double NAT scenario which is not good.
To know more about Double NAT, kindly access the articles below:
How to fix issues with Double NAT
Since you need a wireless network, you may want to consider the network setup below:
For example, you have a 2-storey house (or office). From the network diagram above, the modem is connected to the WAN port of the BR500 firewall router. The BR500 firewall router supports VLAN. You will need to configure VLANs to segregate networks. For example: you need to separate the Private (or Admin) network from the Guest network. A LAN port of the BR500 firewall router is connected to a port of the GC510PP smart switch. The ports connecting the BR500 firewall router and the GC510PP should be configured as tagged ports so that it will become a trunk link. Tagging the ports is needed in order to identify which VLAN the packet belongs to.
The GC510PP smart switch supports VLAN as well as PoE (Power over Ethernet). One port of the GC510PP is connected to the WAC510 access point deployed at the 1st floor and another port of the GC510PP is connected to the WAC510 access point deployed at the 2nd floor. Since the GC510PP supports PoE, it can power on the 2 WAC510 through its ethernet port to where it is connected to.
The ports connecting the GC510PP and the WAC510 should be configured as tagged ports as well because the WAC510 is a VLAN-aware device. Since the WAC510 also supports VLAN, you can assign a wireless network dedicated to the Private network as well as assign a wireless network for the Guest network.
To know more about BR500, GC510PP and WAC510, kindly access their respective data sheets below:
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
njbrown21
Jul 22, 2019Aspirant
Thank you DaneA
I am pleased that I will be able to use a VPN on this router to access australian content in another country. I presume that a combination of teh BR500 user manual and the VPN provider instructions will be able to guide me to set this up? - To note i coudl not find any information on either NordVPN or PIA websites about this specific router?
In relation to the wireless issue, do i need to get a switch to allow a wireless router to be connected as an access point or can it be directly connected to teh BR500 router? We will not need privbate and guest networks just one network that we can provide network detaisl for people to join.
Thanks again
Neil
- Apr 02, 2019Retired_Member
