njbrown21
Jul 18, 2019Aspirant
Netgear BR500 - VPN & Wireless
Hi, I an soon to be moving to Brunei and want to be able to access australian content on multiple devices so I recently purchased the insight instant VPN router. I am however not sure as to whether i...
DaneA
Jul 23, 2019NETGEAR Employee Retired
I presume that a combination of teh BR500 user manual and the VPN provider instructions will be able to guide me to set this up? - To note i coudl not find any information on either NordVPN or PIA websites about this specific router?
In setting up an OpenVPN connection with the BR500, kindly read pages 127-134 of the BR500 user manual here.
In relation to the wireless issue, do i need to get a switch to allow a wireless router to be connected as an access point or can it be directly connected to teh BR500 router? We will not need privbate and guest networks just one network that we can provide network detaisl for people to join.
Since you do not need to set up VLAN to segregate the network from guests, you can connect the WAC510/WAC505 access point directly to a LAN port of the BR500. However, you will need to purchase a power adapter to power on the WAC510/505 access point because the power adapter is not included in the product package.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
MrJoshW
Jul 30, 2019NETGEAR Employee Retired
Just to clarify on the VPN question. Are you wanting to be in Brunei and VPN tunnel to a server in Australia so that you can access Australian content? or is the BR500 going to be in Australia and you are going to VPN connect in Brunei to the BR500 in Australia?
- njbrown21Jul 30, 2019Aspirant
Hi, thanks for the response.
looking to have the VPN router setup in our home in Brunei so that we can access Australian content
thanks
- MrJoshWJul 30, 2019NETGEAR Employee Retired
BR500 OpenVPN support is client to BR500 device only. You would use the OpenVPN setup if you want to access the BR500's network resources remotely with the OpenVPN client. With the OpenVPN setup on the BR500 you cannot add custom certificates so you cannot use one from a third party VPN service.
The solution you would need is a VPN tunnel to a remote resource in Australia. The BR500 does support IPSEC which will create a site to site to a remote source. The remote source you'll need to connect to needs to support a proxy which will mask your connection when connecting to it. If you're using a third party VPN service you'll need to find out if it supports IPSEC and proxy. A lot of times the third party VPN services will list which countries their VPN servers are located at and sell you on "masking" or "hiding" your connection in these cases these services would work.
Once you have your VPN service select you'll need to create an IPSEC tunnel from your BR500 to the IPSEC service of the VPN provider and make sure the IP addresses or subnet ranges you want on your local network to participate in to be part of the allowed addresses in your IPSEC config. If everything works when you go to check where "you're located" it should say you're located in Australia as the IPSEC tunnel would be masking your connection with the third parties VPN provider. Some documentation on how to setup an IPSEC tunnel from the BR500 can be found below:
- Apr 02, 2019Retired_Member
