njbrown21
Jul 18, 2019Aspirant
Netgear BR500 - VPN & Wireless
Hi, I an soon to be moving to Brunei and want to be able to access australian content on multiple devices so I recently purchased the insight instant VPN router. I am however not sure as to whether i...
njbrown21
Jul 30, 2019Aspirant
Hi, thanks for the response.
looking to have the VPN router setup in our home in Brunei so that we can access Australian content
thanks
MrJoshW
Jul 30, 2019NETGEAR Employee Retired
BR500 OpenVPN support is client to BR500 device only. You would use the OpenVPN setup if you want to access the BR500's network resources remotely with the OpenVPN client. With the OpenVPN setup on the BR500 you cannot add custom certificates so you cannot use one from a third party VPN service.
The solution you would need is a VPN tunnel to a remote resource in Australia. The BR500 does support IPSEC which will create a site to site to a remote source. The remote source you'll need to connect to needs to support a proxy which will mask your connection when connecting to it. If you're using a third party VPN service you'll need to find out if it supports IPSEC and proxy. A lot of times the third party VPN services will list which countries their VPN servers are located at and sell you on "masking" or "hiding" your connection in these cases these services would work.
Once you have your VPN service select you'll need to create an IPSEC tunnel from your BR500 to the IPSEC service of the VPN provider and make sure the IP addresses or subnet ranges you want on your local network to participate in to be part of the allowed addresses in your IPSEC config. If everything works when you go to check where "you're located" it should say you're located in Australia as the IPSEC tunnel would be masking your connection with the third parties VPN provider. Some documentation on how to setup an IPSEC tunnel from the BR500 can be found below:
- Apr 02, 2019Retired_Member
