RayAnderson
Feb 20, 2013Novice
on fvs318g, how to see names and macs on local connections
On my old fvs318 I could see the connections to the local ports. How can I do that with my new fvs318g?
jmizoguchi
Feb 20, 2013Virtuoso
AT&T 3G cell is pain. Prosecure UTM of mine could not activate but used fvx538 to make it work. After activation was some it worked in prosecure
If you had 3G already activated and used with old router then uPnP enabled I'm the router should work.
