train_wreck
Dec 15, 2016Luminary
One more time.... RemoteAccess IPsec XAuth w/certificates on FVS336Gv3 <-> Android 6.0.1
Gonna ask this one more time........ Trying to setup a certificate-based remote access VPN between the FVS336Gv3 and an Galaxy S7 running Android 6.0.1. EVERY other VPN router I have used support...
train_wreck
Jan 15, 2017Luminary
Bump.
I'm after an answer here, folks.......
lightknightrr
Jan 16, 2017Tutor
Personal experience? When I receive those kinds of messages, it's because the client is too simplistic to handle to create a tunnel with NetGear's stuff.
Windows, Android...they try to automate / guess a lot of stuff, and they get it wrong; you try to specify the right values, but there aren't any tabs for them...
You might want to try the NCP VPN client for Android. I use that (for a pre-shared key configuration, not RSA); your configuration isn't too dissimilular to my own.
Of course, my pre-shared key config also works with ShrewSoft (Linux and Windows, tested it), so if you're not tied to the RSA way of doing things, maybe give it a shot. The tutorial I wrote is somewhere around here. Or you could try cannibalizing it to get your current config to work...
