StrikedOut
May 29, 2015Aspirant
Open recursive resolver
Hi. I have a FVS336GV2 but I have received the following email from our ISP, what do you advise? Hello, You appear to be running an open recursive resolver at IP address 78.XXX.XXX.XXX that p...
fordem
Jun 02, 2015Mentor
The rules can be disabled/enabled individually, so disable them as step one, once you are certain they are not required, you can delete them.
I would try it with all rules disabled, because, like I mentioned, I've never had to use any - your environment may not exactly parallel the ones I've done, so your mileage may vary.
