musikev
Jul 20, 2020Aspirant
Opening ports in ProSafe SRX5308
Hi all, I'm using a program called Livestream Studio for live video productions and have been instructed to open these ports in my Netgear ProSafe SRX5308 Firewall: These ports are: TCP 80 ...
DaneA
Jul 21, 2020NETGEAR Employee Retired
Welcome to the community! :)
Kindly read pages 149-151 of the SRX5308 user manual here about setting up LAN WAN Inbound Service Rules (Port Forwarding).
Check this link I found online and use it as your guide to open ports in the SRX5308.
DaneA
NETGEAR Community Team
musikev
Jul 28, 2020Aspirant
Dane,
Thanks for your reply. I went through both the manual and step by step instructions multiple times. Looks like I did everything correctly the first time, but I redid it all anyway and I still see that the port is closed. Is it possible that this router doesn't support Port 1935? I have used the same methods to open Port 20101 with success.
Looking forward to any additional insight you might have.
Thanks again,
Kevin
